Which software can i use for this
It’s an S7-300 module and you can use the TIA portal to program it. The programming cable is quite expensive as I recall.
You can use Simatic Manager Step 7, v5.6 is the last version. Those are signal modules, either Digital Input / Output, Analog Input / Output. To confirm which type of module, check on the side of the module, you can see the part number of the module, which will determine the type of module.
Simatic manager v5.6 for windows 10, V5.5 windows 7 All PLC,HMI, Servo Software All PLC,HMI, Servo, VFD manual Free Download
