Measuring the loop current using test diode is one of the important troubleshooting methods. A Test diode can be placed anywhere in the current loop forward biased.
The rectifying diode can be placed in series at anywhere in the loop.
During normal condition the diode conducts easily, that only shows a drop of 0.7 V which is common for forward biased silicon diode.
To measure the loop current, we connect an ammeter parallel to a diode.
The ammeter resistance is much lower than the diode resistance.
As current tends to flow through lower resistance path, the loop current flow through the ammeter.
Without enough current to bais the diode, entire current flows through the ammeter. the diode effectively turns off and conducts 0 mA, leaving the entire loop current to pass through the ammeter.
During this current flow the ammeter reads the amount of current through the loop.
When the ammeter is disconnected the diode resistance produce a 0.7V again and starts to conduct again.
Such a diode may be installed at the nearest junction box, between terminals on a terminal strip, or even incorporated into the transmitter itself. Some process transmitters have an extra pair of terminals labelled “Test” for this exact purpose.
Ammeter is connected to the terminals labelled as “TEST” below and to the right of the main screw terminals where the loop wiring attaches.
Transmitters equipped with analog meter movements for direct visual indication of the 4-20 mA signal usually connect the analog milliammeter in parallel with just such a diode.
