What are the installation consideration of a turbine flow meter
Maintain 10 d and 5d distance upstream and downstream side.10 d and 5 d means the turbine flow meter inlet distance should be 10 times of the diameter of the pipe. Similarly, outlet distance should be 5 D
Install strainer before turbine flow meter it will help the turbine from partial.
Make sure the turbine flow meter should be completely filled with liquid.
