Explain how we can test the coil of a solenoid valve in the control room
We should check the resistance (ohms) and continuity of the coil. So in order to check the SOV coil in the field, we could check the loop or terminal, so we can open the loop from the power circuit. in order to check the SOV’s coil from the control room, we need to check the resistance of the coil.
