How is Smoke Detection Integrated into Fire Alarm Systems?
Smoke Detector Logic in the Fire Alarm System
Objective
The purpose is to identify fires early on, triggering an alarm and initiating a safety response.
Logical Flow
1). Normal Conditions:
The smoke detector continuously analyzes air quality.
No smoke indicates a normal signal (typically the 24V DC loop is intact).
2). Alarm Condition:
When smoke is detected, the internal sensor activates.
The detector’s status changes (resistance reduces or it becomes short).
The Fire Alarm Control Panel (FACP) gets this signal.
3). FACP Actions:
Verifies the detector signal.
Triggers
Visual alarm (strobes or flashing lights)
Audible Alarm (Hooter, Buzzer, or Siren).
Relay Output (for controlling AHU shutdown, fire damper closure, elevator recall, etc.)
BMS/SCADA integration (if needed)
Location Display
The panel displays the actual detector location/zone in the alarm.
Quickly identifies the source of a fire.
Optional Logics
Pre-Alarm Level: Low smoke levels cause a warning before a complete alarm.
Double Knock: The alarm only sounds when two detectors in the same zone detect smoke (false alarm prevention).
Delay Timer: a period of delay to prevent annoying alarms.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
