A current transformer (CT) is an instrument transformer utilized to measure the alternating current in an electrical circuit.
A current transformer safely converts high current into a proportional low current for measurement and protection purposes.
It consists of a primary conductor carrying current and a secondary winding connected to measuring instruments.
The secondary current is proportional to the primary current.
Construction
A CT has a primary winding which is usually a single turn conductor.
A magnetic core is utilized to transfer energy between windings.
A secondary winding is provided to connect measuring (or) protection devices.
The operating principle is similar to that of a voltage transformer.
Working Principle
A high alternating current flows through the primary conductor.
This current produces a magnetic field in the core.
The magnetic field induces a low current in the secondary winding.
The secondary current is safely measured by instruments.
A CT converts high current into a lower proportional current value.
Importance of Current Transformers
Current transformers are essential for accurate electrical measurements.
They provide a safe method to measure high currents.
They are widely used in residential, commercial, and industrial systems.
They play a key role in power generation and distribution networks.
Their reliability makes them essential components in electrical infrastructure.
Common Uses of Current Transformers
1). Measuring and Monitoring Electric Energy
Current transformers are widely used for measuring electrical energy consumption.
They enable safe measurement of high current in power lines.
Direct measurement of high current and voltage is not practical with standard instruments.
Instrument transformers allow accurate measurement regardless of circuit size.
Modern electronic meters can detect very small currents with high accuracy.
Small measuring devices can be used due to reduced current levels.
Multiple meters can be installed in compact enclosures for multi-customer systems.
The transformer core size can be small due to low instrument burden.
Secondary windings can be designed with very small conductor size.
Typical secondary currents can be as low as 100 mA or 0.1 A.
Low secondary current reduces secondary voltage levels.
This allows safe use of clamp-type current transformers.
Self-shorting CTs improve operational safety.
Milliamp secondary CTs are preferred for submetering applications.
These CTs occupy less space in panel wiring.
They eliminate the need for separate shorting blocks.
CTs enable monitoring of individual circuits in buildings or industries.
They support accurate billing based on energy consumption.
2). Protecting Instruments and Power Systems
Current transformers are used for protection against overloads and faults.
These are known as protection current transformers.
The CT secondary is connected to protective relays.
Protective relays monitor current conditions continuously.
The relay sends a trip signal during overcurrent conditions.
Overcurrent can be caused by overload or short circuit.
Circuit breakers operate based on relay signals.
Protection CTs must handle higher burden compared to metering CTs.
The core size must be larger to avoid saturation.
CT saturation must be avoided during fault conditions.
Accurate current reproduction is essential during faults.
Proper CT performance ensures reliable protection operation.
Protection CTs are generally larger in size.
