How does an Electronic Positioner work in Control Valves?
In industrial systems, precise fluid and gas flow control relies on the Electronic Positioner, which ensures accurate valve positioning based on control signals.
How does it Work?
Command Signal: An electrical signal is sent to determine the desired valve position.
Travel Sensor: Measures the valve stem position and provides feedback.
Pressure Control: The signal is converted to air pressure via I/P, then adjusted using a PID Controller.
Position Control: A PI Controller corrects any position errors.
Closed-Loop System: Continuously monitors pressure and position for precise adjustments.
Why is it Important?
Enhances valve positioning accuracy.
Responds quickly to signal changes.
Ensures stable and efficient process control.
