How does an Auto/Manual Float Switch Control System operate a 3-Phase Water Pump?
An Auto/Manual float switch control system is used to automatically or manually control a 3-phase water pump based on the water level in a tank or reservoir.
It ensures reliable water management, prevents dry running and overflow, and provides flexibility for maintenance and emergency operation.
Auto and Manual Modes
Auto Mode: The float switch starts and stops the pump automatically according to predefined water levels, ensuring continuous and unattended operation.
Manual Mode: The operator can start or stop the pump using push buttons or selector switches, regardless of the float switch status, making it useful for testing, maintenance, or special operating conditions.
Importance
This control system improves operational efficiency, reduces manual intervention, protects the pump from damage caused by low water levels, and helps maintain a consistent water supply.
Applications
It is widely used in overhead tanks, underground reservoirs, irrigation systems, water treatment plants, and industrial pumping applications.
