How Does a Motor Control Circuit work using Direct-On-Line (DOL) Starter in Real Industrial Applications?
The following illustration shows a functional motor control circuit that includes both power and control parts.
It is a traditional Direct-On-Line (DOL) starting configuration that is often used in industrial environments. Appropriate for students, field technicians, & automation engineers.
Power Section (Left side - 440V 3 Phase AC)
  • Q1 - Motor Circuit Breaker: Protects motor and wires from overcurrent and short circuits.
  • K1 - Electrical Contactor: Switches three-phase electricity to motor. Controlled by a circuit.
  • Cables & Terminals: Heavy-duty industrial cables & terminal blocks provide safe, heat-resistant wiring.
  • M1 - 3-Phase Motor: The main load is usually an induction motor for fans, pumps, or conveyors.
[color=#1e00a3]Power Flow Path:[/color] [color=#CF2E2E] L1, L2, L3 → Q1 → K1 → Motor Terminals (U1, V1, W1).[/color]
Control Section (Right Side: 220V AC Converted to 24V DC)
  • Q2 - Control Circuit Breaker: Protects low-voltage (LV) control side from faults.
  • Power Supply (AC/DC Converter): The power supply (AC/DC Converter) converts 220V AC to 24V DC for safe powering the control circuit.
  • F1 - Control Fuse: Provides additional protection against the overcurrent in control wire.
  • S1 - Emergency Stop (NC): A normally closed pushbutton that immediately stops the circuit when pressed.
  • S2 – STOP Button (NC): When pressed, the S2 - STOP Button (NC) interrupts the circuit and de-energizes the contactor.
  • S3 - START Button (NO): A normally open pushbutton that accomplishes the circuit and activates the contactor coil.
  • K1 Coil – Contactor Actuation (A1/A2): When energized, the K1 Coil - Contactor Actuation (A1/A2) closes the primary contactor, providing power to the motor.
  • H1 – Indicator Lamp: The H1 - Indicator Lamp provides visual input when the motor is running.
Basic Operating Sequence
  • To power up the circuit, close Q1 (power side) & Q2 (control side) simultaneously.
  • To start the motor, press the START button (S3). The control voltage energizes the K1 coil, the main contactor closes, and the motor starts.
  • To stop the motor, press the STOP button (S2) (or) Emergency Stop (S1). The control circuit opens, K1 de-energizes, and the motor stops.
  • The indicator lamp H1 flashes when the motor is running, confirming its active condition.
Why This Setup Is Ideal Safe?
  • 24V DC control minimizes shock danger.
  • Simple wiring allows for easy troubleshooting.
  • Compliant with DOL starting logic used in automation panels around the world.
Applications
  1. Motorized conveyor belts,
  2. HVAC blowers,
  3. Water pump, and
  4. Small industrial machinery.
