How can you identify transmission line voltage by counting insulator discs?
Suspension and strain insulators in overhead transmission lines consist of several porcelain (or) polymer discs connected in series.
The number of discs is directly proportional to the line’s working voltage because each disc is intended to resist a specified voltage, typically 11-15 kV (RMS) under normal operating conditions.
By count the number of discs in an insulator string, we can calculate the voltage level of the transmission line.
Discs Line Voltage (kV)
3 34.5 kV
4 69 kV
6 115 kV
8 138 kV
11 161 kV
14 230 kV
15 287 kV
18 345 kV
23 360 kV
24 400 kV
34 500 kV
44 600 kV
59 750 kV
60 765 kV
Because of the design margin, each disc is capable of withstanding a particular voltage; nevertheless, additional discs are added to account for pollution, humidity & mechanical strength.
In places that are more susceptible to contamination, such as those that are coastal or industrial, it is possible that more discs will be utilized.
In order to quickly calculate the transmission voltage without having to study complex system designs, field engineers frequently employ a technique known as Quick Field Identification.
