How can PLC Ladder Logic automate a Three-Phase AC Motor?
[color=#ff0000] How can PLC Ladder Logic automate a Three-Phase AC Motor?[/color]
The following example shows a basic [url= Explain Law of Conservation of Charge][color=#1E00A3] PLC [/color][/url] program for controlling a three-phase AC motor with full automatic operation through a user-friendly screen interface. The system has been divided into three major sections:
[color=#ff0000] 1). Power Circuit [/color]
The power circuit shows the whole path of the motor’s electrical supply. Power is routed from the incoming source to a Magnetic Circuit Breaker (MCB) for protection, subsequently via a contactor and then to a thermal relay. The thermal relay protects the motor from overloads, reducing overheating & potential damage from too much current.
[color=#ff0000] 2). Siemens Logo! PLC [/color]
The Siemens LOGO! is a small, easy-to-use PLC designed for small-scale automation operations. Also known as a logic module, it integrates the functionality of a standard PLC, operator interface & communication module into a single unit.
Core Components:
  • CPU: Runs the control program.
  • Integrated I/O: The system includes digital inputs (I1, I2, I3, I4) & outputs (Q1, Q2, Q3, Q4) for interfacing with sensors & actuators.
  • Power Supply: Terminals P1 and P2 can support several voltages (12V DC, 24V AC/DC or 115/230V AC).
  • Display & Keypad: Enables on-device programming, monitoring & diagnostics.
  • Ethernet Interface: Accessible in LOGO! There are eight models that cover networking, programming & web server functions.
[color=#ff0000] 3). Ladder Logic Diagram [/color]
The control logic is executed utilizing ladder logic, a PLC programming language that simulates electrical relay logic with vertical “rails” and horizontal “rungs.” The program consists of 4 rungs.
Rung 1: The motor coil is energized by three contacts (Start, Stop & Trip).
Rung 2: Q1, a normally open (NO) contact, controls the RUN indication bulb.
Rung 3: The STOP indicator bulb is controlled by the normally closed (NC) contact Q1.
Rung 4: When an overload occurs, Input I1 triggers the TRIP lamp.
This configuration maintains consistent motor functioning and provides clear visual feedback for running, stopping & fault conditions.
