How can I interface a PLC and SCADA?
The following are the primary steps that need to be taken in order to successfully interface a Programmable Logic Controller (PLC) and a Supervisory Control and Data Acquisition (SCADA) system:
Step-1: Choosing an appropriate communication protocol, such as Modbus, Profibus, (or) Ethernet/IP, is highly recommended.
Step-2: The PLC and the SCADA system should be connected using the proper wires (for example, Ethernet or serial).
Step-3: In order to configure the PLC, you must first set up the connectivity parameters.
Step-4: In order to connect with the PLC, you will need to configure the SCADA software.
Step-5: PLC data points should be mapped to SCADA tags.
Step-6: To display and control the data from the PLC, you should design the SCADA interface.
Step-7: Perform a test of communication by confirming that the PLC and SCADA are exchanging data.
