What is biometric security?
Biometric security is a type of security that relies on the automatic and quick verification of a person’s bodily attributes to authenticate and grant access to a facility or system. Biometric security is the strongest and most foolproof physical security approach used for identity verification since it examines an individual’s bodily elements or biological data.
Biometric security is mostly used in locations that have stringent physical security needs or are particularly vulnerable to identity theft. Human physical traits that do not change throughout the course of a person’s life are stored in biometric security systems or engines. Fingerprints, eye texture, speech, hand movements, and facial recognition are among them.
A biometric security system or scanner stores an individual’s physical features, which can be accessed by authorised persons. When a person enters a facility or attempts to access a system, a biometric scanner examines his or her bodily traits and compares them to stored records. If a match is found, the person is given access.
What is a Biometric access card and How does it work?
How biometric will help to improve security in manufacturing facilities?
Here we are going to explain how biometric security helps to improve security in your premises.
In today’s world, biometric technology is utilised for a variety of purposes, principally for verification, authentication, and access control. Biometrics offers all of the applications necessary in many scenarios in the production environment. Let’s have a look at them.
Biometric to secure restricted areas
Risk is multiplied in manufacturing operations that employ a lot of oil and gas, chemicals, and heavy machinery. Only well-trained persons are authorized to enter the control room and operate in this situation.
Only the appropriate person has access to restricted areas thanks to biometric authentication. Biometric access control can help prevent unneeded accidents and other problems.
Difference between IRIS scanning and Retina scanning
Biometric systems strengthen security
One of the most significant benefits of biometric security systems is that they may assist you in enhancing your security. Cloning or stealing a fingerprint is far more difficult than cloning or stealing an access card, for example.
In cases where security is an issue, biometrics can also be used for multifactor verification. Someone must, for example, submit their fingerprint after presenting their badge to confirm that they are who they claim they are. This is more secure than verifying with a PIN, which can be easily learned by others.
How fingerprint scanner works and how to choose the best fingerprint scanner?
Improved Accountability
Employee login information can be replaced with biometric technology, which can then be streamlined into other job functions to increase productivity. Employers can easily keep track of their employees’ performance and activities. Because of the reduced corporate control, biometric technology integration can boost employee morale. Furthermore, the technology reduces paperwork, reduces security breaches, and makes audits more efficient.
Biometrics for attendance marking
Many businesses now utilize fingerprint punching devices to track employee attendance. What makes manufacturing plants so unique? Employees at manufacturing or construction sites may wear gloves, or their hands may be oily or filthy, making the fingerprint scanner difficult to distinguish.
So, how do manufacturing firms find a solution? Iris scanning or facial recognition Contactless biometric techniques are used in both cases. Face recognition powered by AI can read masks and dust-absorbent faces.
Biometric logins to prevent cyber attacks
Manufacturers are digitising their data, which includes sensitive information about production processes. Because these data are needed by competitors, cybercriminals have turned their attention to them. Once a hacker has access to the industrial network, they will be able to gain access to critical systems, PLCs, HMIs (human-machine interfaces), and various electrical equipment, among other things. Various passwords and PINs, according to this, are not very secure because hackers can quickly crack them. Biometric authentication, according to studies, is more secure than traditional authentication methods.
Authorized users are authenticated to access PCs and machinery in manufacturing plants using biometric modalities such as fingerprint, facial recognition, palm scanner, or iris scanners. Furthermore, numerous gadgets will be used remotely at various points across the facility and will be visible to all employees, but only authorized personnel will be able to use them. Passwords or PINs are not a reliable way of authentication for such systems. For such gadgets, biometrics is a must-have authentication technique.
Biometric systems improve convenience
Biometric security systems can also make life easier for users. It’s simple to lose track of a card or a key, but your biometrics are constantly with you. If the identification enables hands-free or long-distance recognition, the convenience level rises even more — you could be able to enter your building merely by having your face scanned as you pass through the door.
Touchless solution
You may provide touchless solutions to employees and customers using facial or iris recognition. In our new normal, it’s critical to be able to provide touchless solutions to keep your staff and consumers secure from COVID-19. Furthermore, adopting touchless biometric verification at your building’s access points can eliminate unwanted access and, as a result, improve security. Biometric technology eliminates the costs of lost or forgotten access cards and passwords.
Payments by Biometrics
Biometric technology can be integrated into your point-of-sale system to make transactions more efficient for businesses that sell consumer goods and services. Biometric payment is a POS system that uses biometric authentication to identify the user and approve the withdrawal of monies from a bank account. By submitting appropriate identity and bank account details at a store kiosk, the consumer registers for a biometric program. The shopper merely places their finger on the sensor after registering, and the comparison is completed, authorizing the payment. Biometric payments are simple, safe, and minimize fraud dramatically.
Reduce the chances of Contamination
Contamination can be reduced by using a biometric device. It permits the use of specific drugs based on the company’s skill set. It protects the manufacturing environment and allows team members to operate with a variety of substances and materials.
Furthermore, this technology can work in tandem with AI techniques to determine the roles and capabilities of individuals working with hazardous compounds.
Biometric technology uses voice commands.
Voice commands are incredibly beneficial in a variety of businesses. Everyone has used their voice to engage with smart speakers at home or to ask questions on their phone’s inquiry bar. In this way, voice biometrics advanced to the next level of capabilities.
To acquire the greatest results and relevant information about the asked question, the individual does not need to use their hands to control any system in their native tongue.
