Half-Wave vs Full-Wave Rectifier
A half-wave rectifier converts only one half-cycle of AC into pulsating DC, while a full-wave rectifier utilizes both halves of the AC waveform for improved DC output.
Half-Wave Rectifier
  • Uses a single diode.
  • Conducts during only one half-cycle.
  • Lower average DC output.
  • Higher ripple content.
  • Simple and economical for low-power applications.
Full-Wave Rectifier
  • Uses both positive and negative half-cycles.
  • Can use a center-tapped transformer with two diodes or a bridge circuit with four diodes.
  • Produces a higher average DC output.
  • Lower ripple and better rectification efficiency.
  • Widely used in DC power supplies and electronic circuits.
Difference between Half-Wave vs Full-Wave Rectifier
Parameter Half-Wave Rectifier Full-Wave Rectifier
Basic operation Converts only one half-cycle of AC into DC Converts both half-cycles of AC into DC
Number of diodes 1 diode 2 diodes with center-tapped transformer or 4 diodes in bridge configuration
AC utilization Uses only 50% of the input waveform Uses both halves of the input waveform
DC output Lower Higher
Ripple High Lower
Ripple frequency Same as supply frequency Twice the supply frequency
Rectification efficiency Lower Higher
Filtering requirement Requires larger filtering for smoother DC Requires comparatively smaller filtering
Circuit complexity Simple More complex
Cost Lower Higher
Transformer utilization Poorer Better
Output quality More pulsating DC Smoother DC
Typical applications Low-power and simple circuits Power supplies, battery chargers and electronic equipment
