GP-Pro EX Simulation Works, but HMI Screen Not Displaying After Sending Project (GP4601TADV Model)
If the GP-Pro EX simulation works but the HMI screen is not displaying the project after sending it to the GP4601TADV model, here are a few things you can check:
- Project Transfer: Ensure the project was successfully transferred without any errors. Try transferring the project again and verify if it completes without interruptions. Sometimes, the transfer cable or network connection can cause incomplete transfers.
- Firmware Compatibility: Verify that the firmware on the GP4601TADV is compatible with the version of the GP-Pro EX software used to create the project. If there is a mismatch, update the HMI’s firmware.
- Startup Screen Settings: Ensure that the startup screen is correctly set in the project configuration. If no startup screen is defined, the HMI may not display anything after booting.
- Screen Brightness: Check if the screen brightness has been set too low or if the display has been turned off. It’s possible that the screen is functioning, but the display settings are causing it to appear blank.
- Display Resolution: Verify that the project’s resolution matches the GP4601TADV’s screen resolution. If there’s a mismatch, the project might not display correctly.
- Memory Issues: Ensure that there is enough memory on the HMI for the project. Large projects may not load if there isn’t sufficient space.
- Check Error Logs: View the error logs on the HMI for any messages that might give insight into what’s preventing the project from displaying.
- Reboot the HMI: After the project transfer, try restarting the HMI to see if the project loads properly after a fresh boot.
By following these steps, you should be able to troubleshoot and resolve the issue effectively. Let me know if you like more assistance.
