Gap voltage is feed back voltage derived by setting the standard gap between the eddy probe tip and the rotating shaft.
The gap voltage is the base DC voltage set to get the AC pulses peak per the radial vibration measured on the shaft. The gap voltage is set at –8.00V DC i.e. equal to a gap of 40 mill (between the probe tip and the measuring surface).
