Static Head = pgh p= Density of the liquid g= Gravity h= height of the liquid column
The static head pressure in kilopascals (kPa) is computed using the following formula:
[color=#ff7700]kPa Formula[/color]
P = ρ x g x h
Where
P - Static head pressure in kPa
ρ - Fluid’s density (ρ) is measured in kg/m³.
g - Acceleration due to gravity, which is approximately 9.81m/s2
h - Fluid column’s height (or) head in meters.
To convert pressure to kilopascals (kPa), divide the value by 1000
NOTE-1: 1 Pa = 1 N/m²,
NOTE-2: 1 kPa = 1000 Pa
Therefore, the final formula is:
P = ρ x g x h/1000
[color=#ff7700]Solved Example[/color]
For a 10-meter-high water column:
- ρ (water density) = 1000 kg/m³
- g = 9.81 m/s²
- h = 10 m
P (kPa) = 1000 x 9.81 x 10/1000 = 98.1 kPa
Therefore, the static head pressure would be 98.1 kPa.
- You can also follow us on [color=#1E00A3]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
- You can also follow us on [color=#1E00A3] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
