FLOW TRANSMITTER
Flow transmitters will amplify the signals which are coming from a particular sensor and it will then be used properly such as signal processing or as a display. Flow transmitters are capable to take signals from many sensors according to its circuitry, environment or the place which they are going to be installed it could perform three functions to the incoming signals from the sensor they are amplifying, signal conditioning and converting
IMT25 Magnetic Flow Transmitter
These transmitters are mostly sensors with an electrical transmission output for the remote indication of the flow rate These type of transmitters will be compatible with many flow tubes so that it could check the flow of the liquid it can be used with 2800 and 8000 series flow tubes and it provides an advanced microprocessor based DC pulse magnetic flow system
FUNCTION OF KEYS
There are various types of flow transmitters they are • Differential pressure flow transmitters • Ultrasonic flow transmitters • Mass flow transmitters • Wheel flow transmitters The advantage of this transmitter is low power consumption it can accept either 85 to 264V AC or 24V DC power with the either supply the consumption of the power will be less than 24watts this transmitter provides output signals such as analog, digital, pulse output signals
OPERATING CONDITION OF IMT25 FLOW TRANSMITTER
