A ‘flow factor’ is to multiply the flow transmitter signal measured on a 0-10 square root or 0-100 linear scale to get the flow calculated by flow metering. This is used due to the standardization of the transmitters signals, to 20-100 kPa or 4-20mA. The following points are considered for flow calculation and in deriving the flow factor:
D = pipe diameter, Small d = orifice diameter Service = gas or liquid PI = operating pressure DP = Transmitter differential pressure T =operating temperature Small p= density or molecular weight Small v= viscosity
