HMI always shows this message what will be the reason for this fault. It is not the problem of the communication cable I already change that, please give a solution for this problem
Use a twisted pair cable, this problem could be because of harmonics, and check earthing in the panel can be also helpful.
Change the parity bit and then upload
Check any VFD or electronic device harmonic is preset
Check communication parameters
Check if you have external 24 VDC in the plc
Check the IP’s of both HMI and the PLC
