How relay logic is different from PLC logic
Relay Logic uses relays that were hard wired in a Logic configuration. PLCs are small industrial computer that is programmed logic by using software.
Relay logic : When you make interlock or logic (by making serial or parallel combination of relays or contactor) via hard wired.
PLC logic : When you make interlock or logic via software to operate any field equipment or Trip them through PLC.
