Emergency Shutdown (ESD) System
Emergency Shutdown (ESD) System systems serve to prevent escalation of emergencies, such as fires, explosions, and leaks.
  • ESD systems protect worker safety by shutting down processes & isolating areas in the event of a harmful condition.
  • Environmental protection involves controlling spills or leaks & shutting down processes.
[color=#f80404] Components of an ESD System[/color]
[color=#1e00a3] ESD Valve[/color]
Actuated Valves: These are key components of the ESD system that close automatically when a shutdown signal is received.
Pressure Relief Valves (PRVs): Automatically relieve pressure in vessels (or) pipelines to avoid overpressure situations.
[color=#1e00a3] Sensors & Detectors[/color]
Gas Detectors: Determine the presence of flammable or dangerous gases & initiate shutdown procedures.
Fire Detectors: Detect fires using smoke, heat, (or) flame detection, and activate the ESD.
Pressure Sensors: Monitor pressure levels in pipelines & vessels, and activate the ESD if they exceed safe limits.
Temperature Sensors: Monitor temperature in important locations to identify overheating.
[color=#1e00a3] Logic Solver[/color]
Programmable Logic Controllers (PLCs): These are the ESD system’s brains, processing data from sensors and detectors to determine when to trigger shutdowns.
Safety Instrumented Systems (SIS): These systems have PLCs that are designed to meet certain safety requirements.
[color=#1e00a3] Control Panel[/color]
ESD Control Panels: These centralised equipment allow operators to manually activate or reset the ESD system, check system status, and run diagnostics.
Human-Machine Interfaces (HMI): Give operators a visual interface to engage with the ESD system by displaying real-time data and alarms.
[color=#1e00a3] Emergency Shutdown Buttons (ESB) [/color]
Manual ESD Stations: These stations are strategically located around the site and allow personnel to manually switch on the ESD system in the event of an emergency.
[color=#1e00a3] Alarms & Indicators[/color]
Audible & visual alarms: Alert personnel to an emergency & the activation of the ESD system, requiring rapid evacuation or other safety actions.
[color=#1e00a3] Shutdown Procedures[/color]
Sequential Shutdown: The system is programmed to shut down the facility in a certain order to prevent creating additional dangers. To prevent overpressure, stop down pumps before closing valves.
Partial (or) Full Shutdown: Depending upon the severity of the issue, the ESD system can be set to turn off only the affected regions (partial shutdown) (or) the entire facility (full shutdown).
[color=#f80404] Types of ESD Levels [/color]
[color=#1e00a3] Level 1 (Full Plant Shutdown) [/color]
Enables all safety measures and isolates the whole facility.
[color=#1e00a3] Level 2 (Process Isolation) [/color]
Isolates specific process units (or) sections of the plant while leaving others operating.
[color=#1e00a3] Level 3 (Component Isolation) [/color]
Isolates certain components, such as a single pipeline (or) vessel, without disrupting the overall process.
