Maintenance of electrical tools is very important to avoid hazards that may lead to accidents, enhance effectiveness and durability.
To maintain electrical tools effectively, follow these steps:
Regular Inspection
Keep Tools Clean
Proper Storage
Follow Manufacturer Guidelines
Electrical Safety Checks
Handle with Care
Use the Right Tool for the Work
Regular Inspection
Inspect tools before each use for any indications of wear inclusive of; cable damages, casings cracks, or loose parts. It is very important that you eradicate or try to solve any problem that arises as soon as it happens.
Keep Tools Clean
It must be noted that electrical tools must be cleaned often from dust, dirt, debris which may hinder proper functioning over time.
Care should be taken when cleaning in order not to damage certain parts of the circuit.
Proper Storage
Store tools in dry, cool areas to minimize the effect of moisture or extreme temperatures, since they can easily cause corrosion and or harm electrical devices of those tools.
Maintain all recommended instructions given by the manufacturer regarding lubrication of parts, adjustments, and servicing.
Perform checks of tools for grounding, insulation, and electrical activity by regular tests using relevant test equipment.
Handle with Care
Never drop or handle roughly tools for physical shock sometimes causes damage to the internal electrical parts.
Do not use tools for more load than their maximum recommended load in order to prevent overheating of the tools and wearing out of the components.
By following these steps, electrical tools stays safely in working condition which may help to avoid and prevent likelihood of an accident and the tools will serve for a longer time.
