Electrical Substation Inspection – Complete Inspector's Checklist
A substation inspection is much more than confirming that equipment has been installed.
It is a systematic procedure of verifying that every component has been installed correctly, tested thoroughly, documented properly and complies with approved drawings, project specifications, applicable standards, Factory Acceptance Test (FAT) records and site requirements.
Essential Inspection Areas
A comprehensive substation inspection should cover the following essential areas:
Approved Drawings & Latest Revisions – Ensure all work matches the latest approved engineering drawings and document revisions.
Material & Equipment Verification – Confirm equipment specifications, ratings, and nameplate details against project requirements.
Cable Laying, Termination & Identification – Verify routing, gland installation, termination quality, and proper cable tagging.
Earthing & Bonding System – Check grounding connections, bonding continuity, and earthing compliance.
Equipment Installation & Alignment – Inspect mounting, leveling, clearances, torque-tightening, and mechanical alignment.
Control, Protection & Interlocking Circuits – Confirm wiring accuracy and proper operation of control and interlocking schemes.
Testing & Commissioning Records – Review insulation resistance, functional tests, and commissioning data.
Protection Relay Settings & Functional Checks – Verify relay settings, logic, alarms, trips, and secondary injection test results.
Documentation & Inspection Records – Ensure all reports, checklists, certificates, and test records are complete and traceable.
Safety, Housekeeping & Workmanship – Inspect labeling, safety signage, clear access, cleanliness, and overall workmanship.
An experienced electrical inspector follows a simple but effective workflow:
See It - Check It - Verify It - Record It - Report It - Follow Up
Why Quality Inspection Important?
Quality inspection is not simply about reviewing test results. It is about ensuring that every piece of equipment installed on site matches the original design, approved specifications, applicable standards, and verified test records before the substation is energized.
