Which is more harmful, AC or DC?
One of the reasons why AC may be deemed more harmful is that it has more possibilities of entering your body. Because the voltage alternates, current can enter & exit your body even without a closed loop, as your body (and the ground it is connected to) has capacitance. That is something DC cannot do.
Which is more dangerous: current or voltage?
Higher voltage enables the generation of higher, more harmful currents. Resistance opposes current, hence high resistance is an effective shock protection strategy. Any voltage greater than 30 is generally thought to be capable of producing harmful shock currents.
What is the National Electric Code?
The National Electrical Code (NEC), also known as NFPA 70, is a regionally adopted standard for the safe installation of electrical wiring & equipment in the United States. It is part of the National Fire Codes series, which is published by the NFPA, a private trade association.
What is the purpose of the NFPA 70e?
NFPA 70E, or Standard for Electrical Safety in the Workplace, is a National Fire Protection Association (NFPA) standard. The document outlines the electrical safety requirements for employees.
What is the purpose of NFPA 79?
NFPA 79 is the section of the National Electric Code (NEC®) that addresses electrical wiring standards for industrial machinery. NFPA 79 applies to electrical equipment used in a wide range of machines, as well as groups of machines that work together in a coordinated fashion.
What is the CSA Z462 standard?
CSA Z462, Workplace Electrical Safety Standard is a standard of the Canadian Standards Association. It is based on and was developed in parallel with U.S. National Fire Protection Association (NFPA) standard NFPA 70E, Standard for Electrical Safety in the Workplace.
Who is the NFPA?
The National Fire Protection Association (NFPA) is an international non-profit organization established in 1896. The company’s mission is to reduce the worldwide burden of fire and other hazards on the quality of life by providing and advocating consensus codes and standards, research, training, and education.
What is IEC standard?
The International Electrotechnical Commission (IEC; in French: Commission électrotechnique internationale) is a non-profit, non-governmental international standards organization that prepares and publishes International Standards for all electrical, electronic and related technologies
