Electrical Cable Sizing
Selecting the correct electrical cable size ensures safe operation, minimizes voltage drop, prevents overheating, and provides adequate short-circuit protection for the entire installation.
Where:
P = Power (Watts)
V = Voltage (Volts)
I = Current (Amps)
PF = Power Factor
η = Efficiency
Step 1: Calculate Load Current
For a 3-phase circuit:
For a single-phase circuit:
Step 2: Select the Cable Size
Choose a cable with an ampacity greater than the calculated load current after applying all installation correction factors.
Consider:
Ambient temperature
Installation method (tray, conduit, buried, etc.)
Number of grouped cables
Cable insulation type
Voltage drop
Short-circuit withstand capacity
Step 3: Perform a Voltage Drop Check
Where:
L = Cable length
R = Resistance
X = Reactance
ϕ\phiϕ = Power factor angle
The final cable selection must satisfy both the required ampacity and the permissible voltage drop under the actual installation conditions.
