It is a control valve whose trim (plug and seat) has two seats (contact points). A double seated control valve is commonly used in high differential, huge capacity, turbulent flow lines.
The purpose of a double-ported globe valve is to minimize the force applied to the stem by process fluid pressure across the plugs
