Does current flow through the neutral wire when there is no load?
In a completely operating electrical system, when there is no load, current normally doesn’t flow across the neutral wire.
In single-phase & three-phase systems, the neutral wire acts as a return path for current. No current flows when there is no load attached since there isn’t a full circuit.
Small quantities of current may, however, occasionally flow in the neutral line even in the absence of a load under the following conditions:
  • Current Leakage
  • Effects of capacitive coupling
  • Three-phase system imbalances
Yes, even in the absence of a load, current continues to flow over the neutral wire; however, the amount of current is dependent on the system’s balance:
[color=#ff7700] Balanced System [/color]
The neutral current will add up to zero in a three-phase system that is properly balanced and has equal loads on each phase. This indicates that there is no current returning to the transformer through the neutral line.
Because it does not carry any current in a balanced system, the neutral conductor is exactly the same size as each of the phase conductors in a three-phase system.
[color=#ff7700] Unbalanced System [/color]
The neutral wire will return the unbalanced current to the transformer if the loads are not precisely balanced among the phases.
Ex: There will be 5A flowing via the neutral back to the source if one phase is carrying 20A & another 15A.
The size of the neutral wire needs to be such that it can withstand the highest possible unbalanced current.
[color=#ff7700] Single Phase [/color]
The neutral in a single-phase circuit always flows in the opposite direction as the hot wire and carries the same current.
Since the circuit cannot be completed until the current returns to the source, the neutral current is equal to the hot wire current.
In conclusion, neutral current is dependent on the system’s stability. The neutral in a three-phase system that is fully balanced carries no current. However, in single-phase or three-phase unbalanced systems, the neutral returns the return or imbalanced current to the source.
Does current flow in neutral wire?
Yes, the neutral wire absolutely carries current.
In standard AC electrical circuits, it serves as the essential return path carrying returning electrical current back to the power source to complete the circuit.
How it works under normal operating conditions?
In a single-phase circuit system
The neutral wire carries the exact same amount of current as the live (or hot) wire, just in the opposite direction.
In a three-phase circuit system
The neutral wire typically carries only the unbalanced current from the different phases. If all three phases are perfectly balanced, the main neutral wire will carry no current at all.
Voltage levels
While it carries current, the neutral wire is typically bonded to the earth at the main electrical panel. Because its voltage relative to the ground is close to zero, touching a properly connected neutral wire generally does not result in an electric shock.
