Different Types of Relays & their Protection
The different types of relays & their protection are:
  1. Overcurrent Relay (OCR) – It operates when current exceeds a preset value due to overload or fault.
  2. Earth Fault Relay (EFR) – It detects leakage current flowing to earth and trips the circuit.
  3. Differential Relay – It compares currents at two points and operates when there is a difference indicating an internal fault.
  4. Over Voltage Relay – It trips the system when voltage rises above the safe limit.
  5. Under Voltage Relay – It operates when voltage drops below a preset level.
  6. Thermal Overload Relay – It protects equipment from overheating due to prolonged overload.
  7. Distance Relay – It detects faults based on impedance or distance from the relay location.
  8. Buchholz Relay – It protects transformers by detecting internal faults through gas accumulation.
  9. Reverse Power Relay – It operates when power flows in the reverse direction, protecting generators.
  10. Negative Phase Sequence Relay – It detects phase imbalance that causes heating in rotating machines.
  11. Frequency Relay – It operates when system frequency deviates from normal limits.
  12. Restricted Earth Fault Relay (REF) – It provides sensitive protection for internal earth faults within a defined zone.
  13. Over Flux Relay – It protects transformers from overfluxing due to high V/Hz ratio.
  14. Directional Overcurrent Relay – It operates only when fault current flows in a specific direction.
  15. Time Delay Relay – It introduces a preset delay before tripping to ensure coordination.
  16. Instantaneous Relay – It trips immediately when fault current exceeds a set value.
  17. Voltage Balance Relay – It detects voltage imbalance between phases.
  18. Phase Failure Relay – It operates when one or more phases are lost (single phasing).
  19. Lockout Relay – It acts as a master relay to trip and lock the system during major faults.
  20. Auxiliary Relay – It supports control and interlocking functions in protection circuits.
  21. Current Balance Relay – It detects imbalance in current between phases.
  22. Under Frequency Relay – It operates when system frequency falls below the set value.
  23. Over Frequency Relay – It trips when system frequency exceeds the safe limit.
  24. Pilot Relay – It uses communication signals for protection between two ends of a line.
  25. Gas Relay – It detects gas formation in transformer oil indicating internal faults.
  26. Out of Step Relay – It protects generators from instability due to loss of synchronism.
  27. Sync Check Relay – It ensures proper synchronization before connecting two systems.
  28. Vector Surge Relay – It detects sudden changes in phase angle indicating faults or disturbances.
  29. Trip Circuit Supervision Relay – It monitors the health of the trip circuit continuously.
  30. Auto Reclose Relay – It automatically recloses a circuit breaker after a temporary fault.
  31. Thermal Relay – It protects equipment from temperature rise due to overload.
  32. Rate of Rise Relay – It operates when current increases rapidly, indicating a fault.
  33. Directional Earth Fault Relay – It detects the direction of earth fault current.
  34. Power Factor Relay – It operates when power factor falls below a preset value.
  35. Voltage Restraint Relay – It modifies relay operation based on voltage conditions.
  36. Voltage Controlled Relay – It operates depending on voltage magnitude in addition to current.
  37. Current Differential Relay – It compares incoming and outgoing currents to detect internal faults.
  38. Transformer Protection Relay – It provides comprehensive protection for transformers against multiple faults.
  39. Generator Protection Relay – It protects generators from electrical and mechanical faults.
  40. Motor Protection Relay – It safeguards motors against overload, faults, and abnormal conditions.
  41. Busbar Differential Relay – It detects faults within the busbar zone by comparing currents.
  42. Arc Flash Relay – It detects arc faults using light and current sensing.
  43. Phase Sequence Relay – It ensures correct phase sequence to prevent reverse rotation.
  44. Dead Line Relay – It detects absence of voltage in a transmission line.
  45. Field Failure Relay – It operates when excitation in a generator is lost.
  46. Under Current Relay – It detects abnormally low current conditions.
  47. Sensitive Earth Fault Relay – It detects very small leakage currents to earth.
  48. Over Temperature Relay – It trips when temperature exceeds safe limits.
  49. Winding Temperature Relay – It monitors transformer winding temperature to prevent damage.
  50. Oil Level Relay – It operates when transformer oil level falls below the required level.
