Different types of diagrams related to Instrumentation and Control Engineering
Electrical Diagram - Symbols and Diagrams that explain electrical process
Elevation drawings - A graphical representation that shows the location of process equipment in relation to existing structure and ground level.
Equipment location drawing - Show the exact floor plan for location of equipment in relation the plan’s physical boundaries. Flow diagram - A simplified sketch that uses symbols to identify instruments and vessels and to describe the primary flow path through a unit Foundation drawings - Concrete,Wire mesh and steel application that identify width depth and thickness of footings support beams and foundation Legends - A document used to define symbol abbreviation prefixes and specialized equipment Process and Instrument Drawing (P&ID) - A complex diagram that uses process symbol to describe a process unit.Also called Piping and instrumentation drawing
