Comparison of Synchronous and Induction Motor
Synchronous Motor
Speed of Operation - For a given frequency,the speed of synchronous motor is constant irrespective of the load
Power factor based operation - Synchronous motor can be operated over a wide range of power factor,both lagging and leading
Starting requirement - Not a self starting motor
Excitation requirement - A D C excitation is required for the rotor
Cost,Simplicity and Efficiency - Costly and complex motor construction.Highly efficient for low speed drives r.p.m below 300,as their power factor can always be adjusted to 1.0
