Difference Between Speed Sensor & Proximity Sensor
[color=#ff0000] Difference Between Speed Sensor and Proximity Sensor[/color]
Parameters Speed Sensor Proximity Sensor
Purpose Determines the speed of a rotating (or) moving object. Determines whether an object is present or absent without making direct contact
Primary Output Speed (usually measured in RPM or m/s) Digital presence/absence or analog distance
Working Principle Utilize electromagnetic, Hall effect (or) optical methods to sense motion. makes use of optical, ultrasonic, capacitive, or inductive sensors
Typical Output Signal Frequency or voltage in proportion to speed Analog voltage or an on/off signal
Application Monitoring motor speed, Vehicle speed sensors and Conveyor belt monitoring Detecting objects, Counting objects, Position sensing and limit switching
Example A crank-shaft speed sensor in an engine. Metal components on a conveyor are detected by an inductive sensor.
Detects Static Objects? No, only works with moving objects. Yes, it can identify moving or stationary objects.
Contactless Operation Yes Yes
Sensitivity to Target sensitive to the motion only Insensitive to motion, but sensitive to proximity
