Difference between Megger Test and Hi-Pot Test
What is the difference between Megger and Hipot?
The difference between Megger Test and Hi-Pot Test are widely used in
Parameter Megger Test Hi-Pot Test
(Insulation Resistance Test) (High Potential Test)
Purpose Used to measures insulation resistance value Used to tests insulation strength and breakdown capability
Main Function Helps to detects insulation deterioration, moisture, and leakage Used to verifies insulation can withstand high voltage stress
Test Voltage Type DC Voltage AC or DC Voltage
Voltage Level Low to Medium (250V to 10kV typical) Very High Voltage (2kV to 100kV depending on equipment)
Measurement Provides resistance value in Megaohms (MΩ or GΩ) Provides leakage current value in mA or µA
Test Nature Non-destructive test Potentially destructive test if insulation is weak
Risk to Equipment Safe for the routine maintenance Can damage the insulation if weak (or) defective
Usage Frequency Routine maintenance test Commissioning or periodic certification test
Detects Moisture, contamination & insulation aging Insulation breakdown & dielectric strength
Output Result Insulation Resistance value (e.g., 500 MΩ) Pass (or) Fail based on leakage current
Equipment Used Megger (Insulation Resistance Tester) Hi-Pot Tester
Test Duration Short (usually 1 minute) Longer (1–10 minutes typical)
Application Stage Preventive maintenance Factory testing, commissioning, and safety certification
Safety Level Lower risk compared to Hi-Pot Higher risk due to high voltage
