What is the difference between level transmitter, flow transmitter and DP transmitter
The level transmitter detects the level of the solution in the tank, if the level goes low…it sends a signal to control the valve to open/close. Flow transmitter, with its sensors…detects the amount of flow passing through the vessel. Also, send the signal to the control valve either to open/close. DP transmitter.differentiate the pressure in the pipe. Remember it has 2 sides. HP and LP.
