Difference between Converter and Inverter
Converter vs Inverter
A converter and an inverter are both power electronic devices used to change the form of electrical power.
The key difference is that a converter changes AC to DC, while an inverter changes DC to AC.
Both are widely used in industrial automation, renewable energy systems, electric vehicles, UPS systems, and motor drives.
Parameter Converter Inverter
Definition Converts AC power into DC power Converts DC power into AC power
Input Supply Alternating Current (AC) Direct Current (DC)
Output Supply Direct Current (DC) Alternating Current (AC)
Power Conversion AC → DC DC → AC
Main Components Diodes, SCRs, Thyristors, IGBTs IGBTs, MOSFETs, PWM Controller
Output Frequency 0 Hz (DC) Adjustable (e.g., 50 Hz, 60 Hz, Variable)
Output Voltage Fixed or Controlled DC Fixed or Variable AC Voltage
Efficiency High (≈95–99%) High (≈90–98%)
Typical Applications Battery chargers, DC drives, Electroplating, DC power supplies UPS, Solar PV systems, VFDs, EVs, Home inverters
Example Mobile charger, DC power supply Solar inverter, UPS inverter, VFD inverter
Energy Flow AC Source → DC Load DC Source → AC Load
Primary Function Rectification Inversion
