Difference between Buck and Boost Converters
Buck Converter (Step-Down)
Purpose:
Reduces the input DC voltage to the lower output DC voltage.
Output Voltage (Vout):
V out < V in
​Typical Application:
Powering 5V (or) 3.3V devices with a 12V supply.
Working Principle:
The operating principle is to control and smooth voltage using a switch (similar to a transistor), diode, inductor, and capacitor.
Boost Converter (Step-Up)
Purpose:
Increases the input DC voltage to produce a greater output DC voltage.
V out > V in
​Typical Applications:
Powering 12V equipment using a 5V or 3.7V battery.
Working Principle:
An inductor stores energy & releases it at a greater voltage via switching control.
Feature Buck Converter Boost Converter
Output Voltage Less than input Greater than input
Input Current Lower than output current Higher than output current
Function Step-down Step-up
Inductor Position Between input and switch Between input and diode/load
Efficiency Typically >90% when well-designed Typically slightly lower than buck
Complexity Simple Slightly more complex
Application Examples Mobile chargers, CPUs LED drivers, battery-powered devices
Utilization Utilize a buck converter to reduce voltage. Utilize a boost converter to increase voltage.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
