Automatic Transfer Switch (ATS) vs Switchgear
| Parameters | Automatic Transfer Switch (ATS) | Switchgear |
| Function | During outages, power is automatically switched from the primary to the backup source. | Controls, protects, and separates electrical equipment while monitoring the distribution of power. |
| Operation | Operates automatically and without human involvement; can start generators whenever utility power fails. | Can be manual or automatic; controls high voltages & fault currents in electrical systems. |
| Applications | Used for stable power supply in essential facilities such as hospitals, data centers, & manufacturing plants. | Used to distribute power safely in wide range of conditions, including residential, commercial, & industrial. |
| Components | Typically contains a microprocessor control system & switching relays. | Includes circuit breakers, fuses, and other safety devices for managing electrical loads. |
| Power Handling | Typically handles lower voltage applications; built for smooth transition between sources. | Capable of managing high voltages & fault currents; designed to ensure power distribution safety and dependability. |
| Response Time | Quick response time to power disruptions, often in milliseconds. | The response times may vary depending on the configuration & components used. |
| Complexity | Simpler than switchgear; mostly concerned with switching tasks. | It is more advanced since it performs protective and control tasks on many circuits. |
| Maintenance | Requires regular tests to guarantee functionality, but is often easier to maintain. | Because of its intricacy and importance in safety and operation, it necessitates extensive maintenance. |
