Difference Between 2-Wire and 4-Wire Transmitters
Transmitters are the foundation of industrial measurement, yet not all are wired identically. Understanding 2-wire vs. 4-wire transmitters assists in selecting the appropriate one for your process.
2-Wire Transmitters vs 4-Wire Transmitters
Parameter 2-Wire Transmitter 4-Wire Transmitter
Power Supply Powered by a (loop-powered) signal loop. Includes a separate power supply.
Wiring Using two wires for both power & signal. Utilize two wires for power & two for signal.
Installation Simple, less wiring needed. Requires more wiring.
Cost Generally lower owing to less cabling. Higher due to extra wiring & components.
Signal Type Typically 4-20 mA. May be 4-20 mA (or) voltage signals.
Location Suitable for remote (or) outdoor applications. Typically utilized in control panels (or) local configurations.
Power Handling Limited power handling capacity. Can withstand higher loads.
Loop Isolation Shares common loop – may require isolation. Power & signal circuits are readily separated.
Applications Widely utilized in industrial field instrumentation. Used in more intricate or powerful applications.
Example Devices Pressure, temperature, and level transmitters. Analytical instruments and smart transmitters.
You can also follow us on [color=#CF2E2E]AutomationForum.co[/color], [url= https://www.facebook.com/instrumentation.control][color=#1E00A3]Facebook[/color][/url] and [url= https://www.linkedin.com/showcase/81532759/feed/posts/][color=#1E00A3]Linkedin[/color][/url] to receive daily Instrumentation updates.
You can also follow us on [color=#CF2E2E] ForumElectrical.com [/color], [color=#1E00A3] Facebook [/color] and [color=#1E00A3] Linkedin[/color] to receive daily Electrical updates.
