Delta-Delta (Δ-Δ) Configuration in Transformers
In a Delta-Delta transformer connection both primary and secondary windings are linked in Delta (Δ) mode.
Each phase winding is connected end-to-end resulting in a closed triangular loop that allows line voltage to equal phase voltage.
Characteristics of Delta-Delta (Δ-Δ) Transformer
Feature Description
Winding connection Primary: Δ and Secondary: Δ
Phase shift No phase shift (0°) between primary & secondary
Line Voltage Equal to Phase Voltage
Neutral availability No neutral point
Harmonics Circulates triplen harmonics within delta → good for harmonic suppression
Advantages of Delta-Delta (Δ-Δ) Transformer
  • Suitable for unbalanced loads
  • No neutral required
  • Ideal for 3-phase loads only
  • Transformer may operate temporarily regardless if one winding fails (open-delta or V-V operation)
  • Prevents third harmonics from entering system
  • Improvees power quality
  • Lower insulation requirements (each phase connected line-to-line)
Disadvantages of Delta-Delta (Δ-Δ) Transformer
  • Single-phase loads require a neutral configuration.
  • Not appropriate for neutral grounding.
  • Increased short-circuit current compared to other designs.
  • Difficult fault identification under specific conditions (circulating currents).
Application of Delta-Delta (Δ-Δ) Transformer
  • Industrial distribution systems
  • Large 3-phase motor loads
  • Short-distance transmission
  • Open-delta (V-V) backup operation in substations
  • Step-down/step-up across two balanced 3-phase networks without the need for neutral.
