Current Transformer - Ratio Test
Current Transformer (CT) Ratio Test is a fundamental commissioning and maintenance test used to verify that the actual transformation ratio of a current transformer matches its rated ratio. The test ensures accurate current measurement and proper operation of protection relays, metering systems, and monitoring equipment.
Any deviation from the specified ratio can lead to measurement errors, incorrect relay operation, and reduced system reliability.
