Gate Valves
Best Suited Control: Quick Opening
Recommended Uses:
- Fully open/closed, non-throttling
- Infrequent operation
- Minimal fluid trapping in line
Applications: Oil, gas, air, slurries, heavy liquids, steam, noncondensing gases, and corrosive liquids
Advantages: Disadvantages:
- High capacity 1. Poor control
- Tight shutoff 2. Cavitate at low pressure drops
- Low cost 3. Cannot be used for throttling
- Little resistance to flow
Globe Valves
Best Suited Control: Linear and Equal percentage Recommended Uses:
- Throttling service/flow regulation
- Frequent operation
Applications: Liquids, vapors, gases, corrosive substances, slurries
- Efficient throttling 1. High pressure drop
- Accurate flow control 2. More expensive than other valves
- Available in multiple ports
Ball Valves Best Suited Control: Quick opening, linear
- Fully open/closed, limited-throttling
- Higher temperature fluids
Applications: Most liquids, high temperatures, slurries
- Low cost 1. Poor throttling characteristics
- High capacity 2. Prone to cavitation
- Low leakage and maint.
- Tight sealing with low torque
Butterfly Valves Best Suited Control: Linear, Equal percentage Recommended Uses:
- Fully open/closed or throttling services
- Minimal fluid trapping in line Applications: Liquids, gases, slurries, liquids with suspended solids Advantages: Disadvantages:
- Low cost and maint. 1. High torque required for control
- High capacity 2. Prone to cavitation at lower flows
- Good flow control
- Low pressure drop
<img src=â/uploads/default/130/2ce6159b4c1fd95b.jpgâ alt="butterfly valve"width=â191â height=â296â>
