Control of Escalators -PLC Program
We have all seen escalators at shopping malls,airports,etc .Without any further a due let’s see how we can program escalators using PLC
Operation
(1)Let’s assume that the escalator does not move until someone approaches it. (2)When someone approaches the escalator and turns on pass detection switch:0, the illumination lamp lights and the escalator starts to move. (Escalator movement is up only.) (3) The person is carried up by the escalator, and when that person moves off the escalator, pass detection switch: 1 turns ON, and the illumination lamp and escalator return to a non-operating state.
In this example, consider both pass detection switches: 0 and 1 as non-hold type switches. Another assumption in this example is that people do not continue to get on this escalator.
I/O assignments
Input Pass detection switch:0 X001 Pass detection switch: 1 X003 Output Illumination lamp Y000 Escalator drive output Y003
PLC program
When input X001 is turned ON, outputs Y000 and Y003 operate. Next, when input X003 is turned ON, outputs Y000 and Y003 become non-operational.
Also read Continuous bottle filling system using PLC Program PLC Interview Questions with Answers Part 1
How is PLC used in Elevators?
Additionally, it is the PLC that regulates the opening and closing of doors at various floors, and the lift control system is also responsible for controlling the safety switches. It is the one that directs the lift vehicle as it travels between the various floors.
