Automatic control system refers to the use of some automatic control devices, some key parameters in the production of automatic control, so that they are affected by external interference (disturbance) and deviate from the normal state, can be automatically adjusted back to the process required by the numerical range.In the production process, various technological conditions cannot be invariable.In particular, chemical production, most of which is continuous production, the equipment is related to each other, when the process conditions of one of the equipment changes, some parameters in other equipment may cause more or less fluctuations, deviated from the normal process conditions.Automatic regulation, of course, means no direct human involvement is required.
Sabrina Sun on LinkedIn: #outsourcing #costdown #itcontrols #controlcabinets #controlpanels…
