Config Mismatch error when loading an HG(Highway Gateway) point
This error usually indicates that the point being loaded does not match the configuration that is required for it.
As an example, loading a DO point as a LATCHED point type, but the box/slot configuration for the slot is PULSED will give a configuration mismatch error. Make sure that you are loading the correct configuration to the slot.
