Common Mistakes found during Electrical Inspection
Electrical inspections are conducted to ensure safety, reliability, and compliance with electrical standards.
However, several common mistakes are frequently identified during inspections.
1). Improper Wiring Practices
2). Overloaded Circuits
3). Faulty or Poor Earthing
4). Non-Compliance with Electrical Codes
5). Missing or Defective Protective Devices
6). Poor Distribution Board Arrangement
7). Lack of Maintenance
8). Unauthorized Electrical Modifications
Loose connections, exposed wires, incorrect wire sizes, and damaged insulation are often found. These issues can cause short circuits, overheating, and fire hazards.
A common problem is connecting too many devices to a single circuit, which exceeds its capacity and leads to tripping or overheating.
Inadequate grounding increases the risk of electric shock and equipment failure during faults or lightning events.
Use of substandard materials and incorrect installation methods that do not meet safety standards are frequently observed.
Improperly rated or missing fuses, circuit breakers, and RCDs reduce overall system safety.
Unlabeled circuits, loose wiring, and exposed terminals inside panels are common inspection findings.
Dust buildup, corrosion, and aging components are often ignored, reducing system efficiency and safety.
Unplanned extensions or changes to wiring systems without proper design review can create serious hazards.
