- Draw system architecture showing PLC, SCADA/MMI, networking devices communication protocol details like IP address etc.
 - Draw detailed block diagram of any field parameter like temp, pressure reading coming to PLC can be shown on SCADA/MMI.
 - Explain 2 wire & 4 wire wiring concept.
 - Draw block diagram of close loop control. Difference open and close.
 - Draw server client architecture with example.
 - Name different types of timers used in PLC.
 - Subroutine, instruction types,
 - Explain PID?
 - PID Cascade mode, primary secondary
 - Ramp, feed forward
 - Name communication protocols and basic parameters required to establish communication between two nodes.
 - What is difference between signal ground and power ground?
 - Explain redundancy of controller.
 - Master slave concept in Modbus
 - Modbus addressing
 - What is CRC? Parity?
 - Thermocouple –RTD difference
 - Room temp resistance for RTD.
 - IP Address classes.
 - Scan time of PLC.
 - Why 4-20 ma not 0-20 ma?
 - Bump less transfer
Honeywell Yokogawa Invensys Siemens
