When try to change the Experion License at server it prompted with the following error: Licence not successfully changed Licencechage.c,v,Error writing license details.
At the problem server: (a) run and check the dongle key (licheck -dongle) from the command prompt (start>run>cmd) or at Experion command prompt (Start>All programs>…>Diagnostic Tools>Experion command prompt). The result should show the algorithm is “correct” and system number matched the site system number.
Example of running the “licheck -dongle” utility: C:>licheck -dongle
