is it possible to use a vectorless VFD for vertical applications like lift, crane, etc
if you are speaking about VFD vector control encoder less you cannot guarantee the position without an encoder, Encoderless is a good solution for pumps, fans control. All applications where you are not interested in the exact position control, so where the speed control is enough. For Vertical load, you need a break, which must be an integral part of VFD. Vector less or vector full is a matter of performance… With encoder, VFD calculate exactly rotary movement, slip, IR, and much other help to calculate based on actual rather logical calculation without encoder
