Is it possible to use a high pressure valve instead low pressure valve?
Yes. A high pressure valve can be substituted for a low pressure valve. Slow moving valves can be used. Be sure records are kept of the changes. Be sure metals are compatible if welded in line. Be sure valve design is appropriate for application.
