Proper cable sizing promotes safety, efficiency, and dependability.
Important factors include:
Current Carrying Capacity
Voltage Drop
Short Circuit Rating
Environmental Conditions
Cable Type and Insulation
Regulatory Compliance
Installation Method
Future Expansion and Cost
1). Current Carrying Capacity
The cable must be able to carry the intended load without overheating, taking into account the ambient temperature, grouping, & installation method.
2). Voltage Drop
Keep voltage drop to 2-5% to preserve equipment operation, and modify cable size for extended distances.
3). Short Circuit Rating
Determine whether the cable can sustain short-circuit currents based on fault levels & protective device clearance time.
4). Environmental Conditions
To select the appropriate insulation and protection, consider temperature, moisture, chemicals, & mechanical stress.
5). Cable Type and Insulation
Use copper or aluminum conductors with appropriate insulation (PVC, XLPE, etc.), shielding for EMI protection, & correct sheathing.
6). Regulatory Compliance
Adhere to NEC, IEC, BS, and IEEE standards for safety, fire resistance, & installation requirements.
7). Installation Method
Conduits, trays, buried, and aerial installations all have an impact on heat dissipation & performance.
8). Future Expansion and Cost
Plan for prospective load expansion while balancing cost versus long-term performance.
